why doesnt my exhaust sound like a camaro with exhaust
i have a 2006 monte carlo ls4. its basically same set up as a camaro, exhaust comes from manifolds to one down pipe through cat, then res, then splits to two mufflers. i took off the resinator, and put on 2 magnaflow mufflers. is because i still have a cat?or maybe cuz i use two mufflers instead of one? the pipe is 2.5 i think. here is a couple soiund clips
http://videos.streetfire.net/video/F...78452BDB86.htm
http://videos.streetfire.net/video/2...9B59C66390.htm
diffrent cam specs, diffrent cylinder bore, manifolds? It could be anything...it could even be your imaginiation. I bet you took that engine and placed it in a camaro same setup u would think nothing of it!
Later
Later
Most likely it is because the engine is completely different than a Camaro LS1 and that is the same reason no other 302 sounds like a Poopstang. It is just the dezine of the engine.
1 Post
Originally Posted by carrsls1_camaro
dezine
yeah the sound of your car has so many variablys, down to the compression, displacement, shape of exhaust port!, manifold or header shape and on down the line
