Scheduled Maintenance Q's
In the service manual I have for my 99 Trans Am it tells you when to do the scheduled maintenace. I bought my car at 31,900 miles in March of '05 and it now has 37,500 miles on it. As far as I know the only things that have been changed are the tires, brake pads(by the dealership I bought it from)oil and oil filter and air filter(by me). It says to change the transmission fluid and filter at 50,000 miles and the spark plugs and wires at 100,000 miles. Should I change those two(plugs/wires and tranny fluid/filter)any sooner and also what about the fuel filter and the rear end fluid?
Thanks - Dan.
Thanks - Dan.
i got my 99 T/A in march of 05 as well with 33,000 miles on it...it now has 55,000 miles and i just recently had a 60,000 mile tune up and replaced my water pump...man in a year you only put 7k miles on...i dont think u need to do anything to it but oil changes unless u feel u need to change them...
dexron III will start to go bad just like any oil so i would replace it along with my rear end fluid. fuel filter also can't hurt and flush your dexcool should have been done on the 5 year mark...and since you are overdue for that flush make sure everything in your cooling system seems ok (check for rust)
