My Moser 9" is on the Way...
I ended up going with a nodular housing, 31 spline, spooled unit with a 4.11 gear. Anybody else running the same rear? How do you like it?
I guess I better forget about that autocross next weekend...
I ordered my moser 9" yesterday from speed inc. Went with 3.89 & a spool. Cant wait to finally be able to take advantage of the 4000 stall & mickeys. I also picked up a bmr x-stream rear bar for the swap to finish it off.
Good luck! We'll be spooling...
hey guys are you going to be running the spools on the street? And how fast will that eat up a set of tires?any other neg. things about running a spool?I need a 12 bolt or a 9" but trying to save every dollar i can get a locker or a posi later if it is too unbearable.thanks for any info you can give me
He switched to a locker, and likes that MUCH better.
He said he'd have to spin the tires when pulling into a parking spot, or it would "bind up" or somthing.
He has a heads/cam built 396 LT1, with spray.
I have close to the same setup except I have 35 spline axles. Also running 4:11's with a spool. It's not a daily driver but it does see the street quite often and if I had to do it all over again it would still have a spool in it. I don't have to worry about parking lots because if I am going to the store for something I'm sure I won't be taking the T/A. That's what DD cars are for.
I'll make a new thread after a few weekends of driving the car. It sees maybe 3k miles per year, so I don't think I'll be doing too much of this...
Besides, we build RACE cars, right?
