01 Camaro SS Engine codes keep popping up, Scanned, Help resolve....
okay, i have 2 engine codes that have been popping up. then last time i scanned i had a 3rd one,
1st the most common one is
P0300 Random / Multiple cylinder misfire. this seems to only happen when my car almost stalls out because of the cam and drops to 500 rpm until the computer gets it more air and goes back to 900. and rarely when i rev above 6400ish. im not to worried about this one cuz my car is running great
i already changed plugs and plugs wires thinking that may be the problem.
2nd, came on a couple times, but now more frequently so i want to fix it.
P0161 02 Sensor malfunction Bank 2 Sensor 2.
ive heard of bank 2 sensors going often so im guessing this is a common occurance. which sensor is it and how hard is it to change?
3rd Code, just came on once. last time i scanned.
P1133 Bank 1 fuel control shifted lean (faosc)
i tuned my car to be on the rich side all through the rpms, and anything exceeding 6000 rpm i am even more rich, not enough to lose to much power, but just enough to play it safe. id rather run a tenth or 2 slower and be safe.
im not sure what would cause this, i was thinking maybe the 02 sensor, but it is Bank 2. so i am unsure about this one. someone plz help me out here. thanks a lot
