Fueling & Injection - Boosted 550rwhp-600rwhp..fuel system options.. opinions wanted!!!!
Avengeance
04-20-2006, 04:27 PM
Ok.. I know this is fuel related.. but I need the opinion of fellow boosted buddies on this one. :)
I already have a thread going in the fuel forum but with 250 views and only 5 measly votes on my poll I figured Id try here instead.
Quick run down.. mods:
D1SC, 9-10psi, custom blower cam, 6.0L heads, 8rib setup, 60# mototrons, stock rails, stock fuel pump, Procharger supplied inline. *fresh fuel filter* Made 561rwhp @ 5900rpm.. 9psi.. 15* timing.. when we had to shut down because we ran out of fuel. We made more power then anticipated, or we would have done more fuel mods to start with. I want to stick with stock rails... and fuel lines... I really dont think those are necessary for me. Im trying to figure out what pump setup.
What to do about fuel? What are you guys using, those making similar power?
Racetronix recommends single intank + BAP. Other credible sources agree. Others say go totally overkill and do the duals. FWIW Im leaning on the single + BAP.
-Dual Intank Racetronix
-Dual Intank Racetronix + BAP (boost-a-pump)
-Single Intank Racetronix
-Single Intank Racetronix + BAP
I need to get this damn thing ordered and installed real soon... summer is just around the corner. Im tired of short shifting my car with this potent setup I have going. :drive: :judge:
PLEASE VOTE AND COMMENT! THANK YOU!
Josh@KY-Turbo
04-20-2006, 04:31 PM
I would go with the dual pumps and BAP. When it comes to fuel systems do it once and do it overkill. That way more power later has the fuel it needs.
Inspector12
04-20-2006, 05:45 PM
I used a racetronix with a BAP for 569rwhp no problems to speak of. I now have two intake 255's.
Frost
04-20-2006, 06:35 PM
Hey mister, that's MY MSD BAP now... :jest:
Thanks for the hookup, and BTW, I saw a nice solid 18VDC at the pump with it. I still ran out of fuel way before I should have, but the part you sold me worked well...
Racetronix
04-20-2006, 06:51 PM
Call Lonnies and discuss it with him.
http://www.lonniesperformance.com/
Dave D
04-20-2006, 07:10 PM
If you go dual pumps, will the stock rails be enough to carry the load? I thought if you went with that system, you have to change the rails too. Am I wrong??
OldBlue
04-20-2006, 07:46 PM
With a single 255 and a MSD-BAP 550-600rwhp is obtainable. Today my camaro put down 540rwhp with this setup. The fuel issue that I once had is now none existent.
Slowhawk
04-20-2006, 08:45 PM
Single pump,BAP and move the return line to the stock rails.
Inspector12
04-20-2006, 09:01 PM
Yeah it worked for me and apparently Oldblue/Darrin LOL! Glad to hear it worked right for you I take care of my stuff so I had no doubt it would work LOL!
Jeff
WAHUSKER
04-20-2006, 09:26 PM
I'm running a single Racetronix intank, with the ATI in-line, and an Aero 1000 regulator & it seems fine. I'm making 540 at the tires (or ~700 at the motor) with Motron 60s & carry 55 psi + to 7000 rpm @ 7 lbs of boost (65 psi at idle). So your plan will work, but I will probably need to add a BAP when I upgrade to a D-1SC. Like others said, you can't have TOO much fuel.....
i made 570rw and had 11.4 af to the end of the run, single ractronix setup. dont know how it does beyond 5800rpm but i will soon let you guys know
Country Boy
04-21-2006, 07:50 AM
Check out the stuff Nasty Nate has. Looks like some good stuff!
http://www.nastyperformance.com/FuelSystems.html
markp03
04-21-2006, 09:17 AM
damn now thats a nice fuel system....too bad i don;t have $1500 sitting around for a fuel system =)
FWIW I'm making 541 w/ a D1SC to 8 lbs. Ractronics pump kit AFR is 10.9-11.3 up to 6000 and gets to about 11.7 at 6400.
mdhmi
04-21-2006, 08:32 PM
I run 600 rwhp with a single Racetronix pump and 60 # injectors. No BAP.
Mark
30th t/a
04-22-2006, 09:34 AM
Mark
not to mislead the Fbody owners...corvettes have a better fuel setup than the F bodys. i believe better fuel lines so they dont need a BAP.
bad95killer
04-22-2006, 09:53 AM
Exactly..my buddy's C5 pushing 550rwhp with 42# & w/o BAP !!! :)
peace
Avengeance
04-23-2006, 02:07 PM
Another Q for you guys, I already have a inline Procharger pump.... I believe its just a 255lph inline? Im not sure of the specs on it.
If I LEAVE that there... and install a Racetronix intank with a BAP... should be good to go, right?
*edit*
Oh yeah.. thanks for all the replies, appreaciate it!
Frost
04-23-2006, 06:28 PM
I was told not to go that route because the fuel bucket will have recovery issues...
Drewstein
04-23-2006, 11:46 PM
I run a single racetronix pump with no BAP and have no issues. I converted to '97 rails though. It's a cheap and effective swap that looks stock as can be.
Josh@KY-Turbo
04-24-2006, 01:59 AM
This has got me thinking about my setup. I have an Aeromotive A-1000 that I was gonna sump my tank and use along with my Aeromtive fuel rails. I am planning on moving up to a T76 from my T70 Hybrid. I would love to just drop in a dual intank setup and be done with it. Where car the dual Racetronics Setup be bought for a 98 Z28? Lonnies only shows it for the 99+ cars.
1936FordPU
04-26-2006, 07:06 AM
A single A1000 on a FI setup will only support about 650rwhp....Give it a voltage booster and it will support more.
Im not a fan of the intank setups simply because all the complaints about noise from the Aeromotive and other externally mounted pumps. I mounted my A1000 to the frame rail behind the drivers side rear tire....on some rubber Isolators from an MSD ignition kit and never once did I hear an obnoxiously loud noise....If i had to do it all over again for street duty high HP application Id run a King Sumoo.
Hope this helps.
super_kev
04-27-2006, 07:45 AM
peace
So can you use the stock line on the f-body as a return, upgrade the pressure side to a bigger braided line, upgrade to a in-tank 255 and be fine for a boosted 550rwhp setup?
Gold Phoenix
04-27-2006, 08:37 AM
I would do dual in-tank because it would be close to the same price, you have enough fuel flow for future upgrades, and if you still need more you can add the BAP.
Inspector12
04-27-2006, 08:40 AM
*edit*
It has been tried and if you put the BAP on the inline that stock pump will be a restriction, and then if you put the BAP on the stocker the inline will be the restriction.
MiaSSmaro98
04-28-2006, 08:57 PM
wats the bap?
OldBlue
04-28-2006, 09:13 PM
B- Boost
A-A
P-Pump
99.9percenter
05-27-2006, 07:28 PM
What about running 16 volts to both?
Bryan Wilkinson
05-27-2006, 09:14 PM
Your problem is in the logs, lines and pump. The pump upgrade may get you over the fuel problem now, but going any futher, will required bigger lines and bigger rails. You need fuel sitting and waiting to be used. Otherwise you could run into a lean condition. 60# injectors are more than big enought for what you are trying to do. You just need to supply them with fuel. A single Aeromotive 1000 and regulator and larger lines and rails would do the trick.
Racetronix
06-08-2006, 06:55 AM
Did you call Lonnies and discuss it with him yet?
Avengeance
06-09-2006, 12:44 AM
No I didnt... I actually got a single intank Racetronix from a shop in Las Vegas because for some reason my buddy couldnt order one from you directly... the Vegas shop had one in stock.
Ive decided to go ahead and run the Single PNP in the tank and a seperate line, tapped into the tank, to the front with an inline 255... then into a Y block and from there into the rail. Hobbs switch to activate the inline @ 3psi. The shop that suggested this has seen great results with this setup.
Thanks though!
Blownramair
06-10-2006, 10:18 AM
I was in the SAME shoes you were in at one point... I went with a complete F.A.S.T. kit for boosted cars up to 900FI HP... System is a complete kit and looks phenominal... Not to mention the performance of it... System is not that difficult to instal... Just about 6 bulkheads... I alos used a set of 55lbs injectors... Hope this helped...
I use C10 Fuel
Jay
cablebandit
01-18-2007, 03:38 PM
i used 97-98 vette rails ...ran a return....2 intanks 255pumps....stock feed line....fine at 800rwhp for me
BrianC98Z28
02-16-2007, 11:50 AM
Does it matter how the power is made?? Just wondering because Im looking at doing heads in the future and with heads/cam/nitrous it should be around 550-575rwhp on the nitrous. I was looking at doing the racetronix PNP kit,36lb injectors. Should I look at the BAP along with it too?
Nasty N8
02-19-2007, 12:33 PM
That pump should get you to about 600rwhp but I would add the BAP just for the added insurance. You do not want to go lean with nitrous.
Kenny Bell BAP $225
Nate
ChevyChad
02-20-2007, 09:29 PM
This is my exact situation for my current build. Looking for 550~600rwhp with ~10psi on a forged 347. Looks like a single racetronix pump system with a KB BAP and some fuel rails and 60# injectors should be sufficient with the stock lines (if I am reading this correctly)?
farmdawg
03-04-2007, 07:06 PM
Reading all of this info has got me wondering if my setup is gonna work for 550-600rwhp. I'm running a forged 347, walbro 340 w/hotwire kit, 6.0 heads machined to 72cc chambers and 10psi boost. I bought a kit that advertised running 42#SVO's, but I had already bought 44# Accels. Does this setup sound like it will work, or do I need to upgrade injectors, or what else?
SSilverSSurfer
03-04-2007, 11:10 PM
i think u should do the 60lb injectors
Nasty N8
03-06-2007, 09:36 AM
If you are looking for about 600rwhp on boost you are going to need some more fuel than one pump is capable of. 550 maybe with upgraded lines and regulator up front and a BAP but I rarely see 600 out of a single pump. Boost requires alot of fuel make sure you have enough. Excess is always good as boost is addictive.
Nate
Frost
03-08-2007, 07:29 PM
I made 600RWHP at 10psi. I was running 12.5psi on 1 pump & METH (and rails, BAP, fmfpr, etc), but pressure was plummeting into the high 30s psi range. I cheated the tune for a month since the pressure drop was repeatable but I wouldn't advise such.
