New Hptuner/Eio
Old 04-20-2006, 05:32 PM
SLP4CamaroSS's Avatar
Default New Hptuner/Eio
how do u connect a lm1 to the new hptuner/eio?
Old 04-20-2006, 05:42 PM
LS1TECH Sponsor
Magnus's Avatar
These links may help:
http://www.hptuners.com/help/vcm_sca...connecting.htm
http://www.hptuners.com/help/vcm_sca...nstall_lc1.htm
Old 04-20-2006, 06:08 PM
horist's Avatar
^^^that pretty much gives you all you need
To summarize:
1. Analog out goes into input #1
2. Analog Ground goes into ground input on cable
3. Program LM1 for desired range (I have mine setup for 10-16 AFR, 0-5 volts, w/a custom wideband PID)
4. Add PID for wideband to your scanner table
and you're set... LM1 is really easy to hookup... just two wires to HPT basically
Old 04-20-2006, 06:28 PM
custome widebad pid?
Old 04-20-2006, 06:36 PM
bmfcamaro's Avatar
no. they have the lm1 preconfigured
Old 04-20-2006, 06:39 PM
on my lm1 i see a gold white and red wire
and i heard u got to ground it to your car and then to the eio or wahtever
Old 04-20-2006, 07:12 PM
horist's Avatar
the instructions say which one is analog 1 and 2 and which is ground, just need the ground plugged to the EIO , and analog 1 plugged into the cable ... w/LM1 it's just two wires
The main ground for the LM1 is the cig lighter
The reason I created a custom userdefined PID for my wideband is i am using non pre-defined ranges (10-16 at 0-5v instead of 10-20 at 0-5 volt)
