Injector question ?
Originally Posted by SPRAYED 01
Do the fuel injector play any part in a wet kit? Or does the fuel solenoid completly take over when spraying?
I'm no nitrous expert, so maybe somebody will correct me if I'm wrong.
Restricted User
Nope nostya you got it basically correct. Fuel injectors merely supply the engines naturally aspirated fueling. One thing you want to watch for is fuel starvation, wet kits tapped off the rail tend to suck the fuel from the injectors, without having a rail mount regulator, end result watch cyl #5 and 7. GL
Charlie
Charlie
