How hard is it to replace the universal joint? (rear)
Old 04-21-2006, 01:01 PM
Sick99WS6's Avatar
Default How hard is it to replace the universal joint? (rear)
Mine is starting to clink real bad everytime I put it into gear and very consistently when the car shifts so I think I have waited long enough. Dealer quoted me at $100 for the part and $175 to install. I would rather do it myself if I can. I do not have the extreme amount of tools since I moved but the necessities. He said I would have to drop the exhaust also. Thoughts? If anything, is it easy enough I could take it to a Goodyear or somewhere for cheaper?
Also, found a Lakewood U-joint at Autozone for $44 versus their $100. Opinions?
Old 04-21-2006, 01:31 PM
2001NBMZ28's Avatar
Sounds awfully high to me. I'd remove the driveshaft myself (just 4 bolts and you don't have to remove the exhaust) buy the U-joint and bring it somewhere else to get it replaced. Sure it's the U-joint and not a bad tranny mount?
Old 04-21-2006, 01:32 PM
Racer8102's Avatar
It's not too bad really, just need I think a 7 or 8mm wrench, I use a ratcheting wrench, I don't know about having to drop exhaust, I have TD's, but I don't think you will, unbolt the straps holding the U joint to the yoke of the rear, slide the ds out of the tranny, some fluid will come out so have a rag handy. The factory u joint has plastic holding the u joint into the ds, use a small torch to heat it up enough to melt the plastic and I use a socket the same size as the u joint bearing cap to hammer the u joint out. put new u joing in in reverse of removal, some times they are a pain to put back into the ds, but if you have a vice or even a smal hammer a little force is all it takes. Spend the time and not the money and you will be proud you learned more about your car. I would reccomend a precision from napa, I have installed a few of that brand and never had any trouble with them, I have one on my car right now and had zero probs with it. Good luck!
Old 04-21-2006, 04:08 PM
Sick99WS6's Avatar
I will replace the tranny mount anyway b/c I liked my old poly one in the Z but pretty sure it is the U-joint. I don't think the mount would make a metal on metal clink noise. Thanks for the help. Think this will be something done in the driveway. I took apart my LT1 and installed a cam. How hard could this be?
Old 04-23-2006, 02:33 AM
Strahley's Avatar
They charge $175 to install U-Joints? Jeez
Old 04-23-2006, 07:27 AM
koolrayz's Avatar
275$ for a u-joint replacement good price
The best way i have ever found to diagnose a bad u-joint was to visualy inspect it. there is a rubber seal in the end of the cap. if its distorted in any way the u-joint is bad. An old man once told me this trick and it worked every time. (i guess im the old man telling the trick now )
Quick Reply: How hard is it to replace the universal joint? (rear)
