WOT switch mounting
I do not have a universal bracket picture handy. But you will need to twist the bracket to fit your needs. It works you just have to be creative. If all else fails we do have a machines bracket out a billit alluminum that just bolts on.
http://www.nitrousoutlet.com/catalog...product_id=821
Dave
Dave
I installed mine and I hated the way it looked. The rest of my kit was hidden and then there was this silly WOT switch just hanging in the open.
I got one of the electronic wide open throttle sensors from Harris Speed Works, I love it. It was easy to install and you can put it wherever you want.
I'm still not sure why these universal brackets are being used when they are so unsightly. It just seems if you put so much time into your engine and mods and making things look nice and neat then you'd want a nice WOT switch that just bolts right up - to finish off the hard work.
i just put my temp one in so i can go to the track i ordered the custom bracket from nitrous outlet. it is not the prettiest thing but hey it will work for tonight. i had to bend the bracket and also the tip of the WOT switch. but make sure the bend is after it passes the little button that is under the activation lever. hope this helps.
