Boss's LT1
Old 04-21-2006, 02:24 PM
2kSnakeEater's Avatar
Default Boss's LT1
My boss has a 94 Z28, his SES light is on and he was told that there is a sensor under his manifold that had gone bad, but was quoted $600 to fix it. Im not too familiar on the LT1, is there such sensor under the lt1 manifold?
Old 04-21-2006, 02:38 PM
ok I found out more info on it,
He gets 12 mpg on the Z, bought the car new and hasnt gotten a speeding ticket in 20 years.
Light comes on when car gets to operating temp, and comes off when driving. Seems like a heat thing.
Ari G's Avatar
more details please and 600$ for a sensor is pretty high
Old 04-21-2006, 02:42 PM
thats what I told him, even Installed.
on a red light, it comes on If you put it in neutral.
Old 04-21-2006, 02:45 PM
skatinjay27's Avatar
there is a sensor under the driver side manifold that is a temp sensor ,but no way it would cost 600$
Old 04-21-2006, 03:05 PM
blkchevyz's Avatar
if you get the code that would help us alot.
there's no sensor under the intake manfold... if there talking exhaust yeah it could be a temp sensor, or knock sensor, o2 sensor, oil level sensor... but hell you could get all those replaced for less then 600
have him check fuses... it could be the air pump going out... if it is the fuse will be blown
Old 04-21-2006, 03:28 PM
infinitebird's Avatar
As said check the code, and no sensor costs anywhere near that much.
Old 04-21-2006, 03:51 PM
I tried, he said he been driving it like that for the last 2 years so he doesnt care to fix it. His mechanic (that he has been going to for the last 20 years) told him it would cost $600 to replace it because of all the labor.
same mechanic that said he would fix his pass. side window for $350
Old 04-21-2006, 03:57 PM
blkchevyz's Avatar
man the only thing that i can think of that cost that much would be an opti with labor.
but i dont see a 94 throwing a code for that(since there's no crank sensor) specially if its still drive able
Old 04-21-2006, 04:07 PM
99.9percenter's Avatar
He gets 12 mpg on the Z, .
It is his oxygen sensor(s) He needs a mechanic that is not hooked on drugs.
Old 04-21-2006, 05:21 PM
OutlawZ's Avatar
labor on drivers side temp sensor would be labor for unscrewing it and screwing it back in......
you can get it out without removing the manifold..... i'v edone it several times...
Old 04-21-2006, 07:53 PM
97blkz's Avatar
You could send him to RX 2k!
Old 04-21-2006, 09:31 PM
Schweet97Z's Avatar
just because he gets 12 miles to the gallon doesnt mean its his oxygen sensors. he has a SES light so its throwing all kinds of fuel at it which will get him horrible gas milage. what you need to tell your boss to do, is go to autozone and get the car scanned for FREE and they will tell him the code, and whats wrong with it. once he tells you whats wrong with it, post back up and let us know so we can give you further advice.
Old 04-21-2006, 09:33 PM
harvickgm's Avatar
his mechanic is on crack... it wouldnt cost 200 dollars to replace all those sensors.... well maybe close depending on the cost of the O2's.... but all of those sensors are cake... they are all easy to get to .... tell him to find out the exact code number and we can help you better...
Old 04-22-2006, 07:34 PM
I told him if he can get me some codes I can fins out whats wrong, and RX was the first place I told him to go, thats how I got the "Iv been going to this mechanic for the last 20 years" bit.
Quick Reply: Boss's LT1
