Sponsored by: DashLynx
front grill question
Old 04-21-2006, 05:02 PM
jaylouky502's Avatar
Default front grill question
i can get the black factory grill out i guess thats Styrofoam behind it is that there for a reason or can i remove that????
will i have to worry about hitting the airbag sensors???
Old 04-21-2006, 05:13 PM
sills1's Avatar
I could be wrong, but I think the styrofoam is there to help support the front bumper assembly. It is possible that it could sag over time if you remove the styrofoam. You can always cut out holes in the styrofoam if you want, but if you put mesh over the holes, it will look fine.
I am going to purchase a Wings West insert, it comes with mesh for the holes. It is easier than having the mounting holes filled in and repainted.
Old 04-21-2006, 05:25 PM
would it help for air flow if i cut out where the holes are?
Old 04-21-2006, 05:29 PM
sills1's Avatar
It would if you ran hose from there to the bottom side of the intake, it would be like a ram air addition. The intake is at the bottom front of the airbox from the factory, but you can do the free ram air mod/enhanced version.
Old 04-21-2006, 05:43 PM
yeah but wouldnt rain run up the hose as i drive????
Old 04-21-2006, 05:51 PM
sills1's Avatar
I highly doubt it, I've seen it done before. But I'm no expert. Don't take my word for it, maybe someone else here will respond. Good Luck
Old 04-21-2006, 05:53 PM
Ling_650vette's Avatar
Could, but there wouldnt be enough pressure to push the water up thru the tubing into the intake IMO.
Old 04-21-2006, 05:58 PM
2002_Z28_Six_Speed's Avatar
Hitting the airbag sensors? Are you cutting your car in half where the center console is or something?
Old 04-21-2006, 06:00 PM
well seeing as i dont know where the sensors are i was guessing they are in the front of the car!!! if im wrong tell me
Old 04-21-2006, 06:54 PM
ESMsilver00SS's Avatar
Where in the hell are you finding a Wings West grille, I didn't think that those were available anymore.
Old 04-21-2006, 11:17 PM
sills1's Avatar
Call them, I did, and they still produce them. That is a rumor that they stopped.
Old 04-22-2006, 10:15 AM
Thanks man, I gave up on getting that grille a long time ago. I really appreciate it
