WOT shifts points w/ HPT still bad!!!!
Old 04-21-2006, 05:44 PM
seadoo's Avatar
Default WOT shifts points w/ HPT still bad!!!!
I have a 4000 stall, w/ a 26" tire and stock 3.23's and have my WOT Shift RPM vs. Shift at 6400 on the 1-2 and the 2-3
my WOT Shift Speed vs. Shift is 45 for the 1-2 and 74 for 2-3
but its still taging the limiter on the 1-2 which is set at 6600!!!!!!!!!!!
Old 04-21-2006, 07:09 PM
seadoo's Avatar
anyone!
Old 04-21-2006, 07:11 PM
LS1TECH Sponsor
foff667's Avatar
sometimes 200 rpms leaway on the 1-2 shift isnt enough thats why many use mph rather then rpms as the main trigger on the 1-2.
Old 04-21-2006, 07:21 PM
Russ K's Avatar
Do you have 3.23 or 3.73 gears? Post your file and I'll take a look at it.
Russ Kemp
Old 04-21-2006, 07:29 PM
gillbot's Avatar
pull the rpm on the mph section down a little so it meets that parameter. That fixed it on mine (but I use edit so I'm not sure how HPT's tables are)
Old 04-21-2006, 07:32 PM
seadoo's Avatar
thanks, maybe I should try the mph....
3.23's
here you go... my lasted bin
EDIT: files to large, even zipped?
Old 04-22-2006, 10:49 PM
Russ K's Avatar
Post your hpt/bin file at hptuners.com/forum/ under GM V8 Engine Tuning-Gas Vehicles. I see you can't post bin or hpt files on this forum.
Russ Kemp
Old 04-22-2006, 11:47 PM
Doc
Doc's Avatar
Your WOT Up Shift at #Speed is > than your WOT Down shift correct?
What I am getting at is you didn't just jump in and adjust one and not the other?
Old 04-25-2006, 09:52 AM
tunedportcj5's Avatar
hmmmm...
Old 04-26-2006, 04:53 PM
seadoo's Avatar
hey, i got it....
all it took was decreasing the mph by ONE and got my 1-2 and 2-3 perfect...
damn, 1 mph...
thanks all for your help
Old 04-26-2006, 05:00 PM
LS1TECH Sponsor
foff667's Avatar
glad you got it worked out...sometimes 1mph can = 200 rpms.
