driver-side power window rattles
drivers side power window rattles........any help??
every time i put my window 1/2 down or abit lower(not all the way down) it rattles...its driving me crazy. any suggestions on how i should go about fixing it..obviously i have to remove the door panel to get to it .but what then???
Copy & Paste Moderator
If the rattle is more than "normal", then it sounds like a broken giude.
I say "normal" because with the design of these doors, the windows will rattle somewhat in the down (1/2 way or more) position. But the rattle typically only happens when opening/closing the doors.
There are two metal brackets with felt pads that help "guide" the window. Take off the door panel and look for the two yellow metal "L" brackets at the top of the door (where the window goes up/down). If one is broken/missing, replace it. They may be held in with rivits. One of mine broke once.
same thing happen to me , i took the car to the dealer and on my way there it stop half way down. they said it looked like somebody tryed to fixed it. i told him i had gotten the car used.so it had a fryed motor,relay,and the window was off the rails and it was going to cost about 500.00 but at the end it sounded 500.00 bucks quiter
