Axle Problems
Old 04-22-2006, 12:28 AM
donalr76's Avatar
Unhappy Axle Problems
Are F-Body axles known for porosity and pitting from bad casting?
Old 04-22-2006, 01:36 AM
chicane's Avatar
Are you talking about the axle bearing surface itself ??
Old 04-22-2006, 04:25 PM
TRex's Avatar
I don't think it is caused by bad casting, as the axles are not cast. It is more likely caused by the combination of a relatively small bearing and relatively low hardness of the surface.
Yes, it is a common problem in higher mileage cars or cars that have had impacts to the rear wheels.
Old 05-06-2006, 10:40 AM
donalr76's Avatar
My car only has 53K mi. and it has not been in any accidents. I do agree it looks like the bearings in my car were harder than the metal spray that is on the axle where the bearing runs...
Old 05-06-2006, 11:02 AM
donalr76's Avatar
I put my new Moser 4-channel axles and a 10-bolt support cover on Wednesday. My roaring noise is gone. I changed the bearings too...
Old 05-08-2006, 10:59 AM
Studytime's Avatar
Can you comment on the quality/craftsman ship of these axles?
Ben T.
Old 05-08-2006, 09:30 PM
donalr76's Avatar
Thumbs up
The Moser Axles were of much better quality than the stockers. The Moser's look steel and the stocker's look like cast iron. I will be pleased with them if their hardness holds up.
Old 05-10-2006, 03:31 PM
Studytime's Avatar
Just wanted to say that they definitely are NOT cast iron, they are a hardened steel. Not quite the same quality as the Moser set, and the Moser axles are rolled/stamped instead of cut like the GM ones are.
Glad to hear they look real nice.
Ben T.
