Impeller speed
Old 04-22-2006, 12:23 PM
wicked_95z's Avatar
Default Impeller speed
What the formula for figuring out impeller speed?
Old 04-22-2006, 02:02 PM
KraZy's Avatar
Procharger + smaller pulley + more belt slip = you letting me weld turbo pipes for you.
Old 04-22-2006, 02:18 PM
wicked_95z's Avatar
Like I told Kevin(ss) if it breaks this time Im getting rid of it. But according to everyone with SDCE it will slip no more, so we'll see. But I will be doing an FMIC as soon as I sell my twin setup
Old 04-22-2006, 09:35 PM
Blown SS's Avatar
Crank pulley inches, divided by blower pulley inches, x step-up ratio x max. rpm's
Example : 7.25 x 3.7 = 1.959 x 4.10 (p1sc-1 step-up) = 8.03 x 6500 rpm = 52,219 impeller speed
Old 04-22-2006, 11:19 PM
LSs1Power's Avatar
You need to correct the sign you have there.
I usually do it this way which makes it easier to change the value of the SC pulley to figure out what you exactly need.
(Crank Pulley*max RPM*Step up ratio)/ SC pulley
(7.25*6500*4.10)/3.70= 52,219 impeller speed.
Old 04-23-2006, 10:28 AM
wicked_95z's Avatar
Sweet....3.4 pulley it is. Thanks fellas
