Air Conditioning broken in AZ!
Old 04-22-2006, 03:57 PM
ReD95LT1's Avatar
Default Air Conditioning broken in AZ!
Alright, question about my ac.
Usually when you turn on the ac you can hear the compressor turn on and the engine kind of makes a noise, the air blows and gets cold.
Now with mine, i turn it on and hear nothing, air blows but not cold at all, what could be wrong?
Old 04-22-2006, 04:02 PM
383LT1S10's Avatar
Really hard to say for sure. First I would check the a/c fuse to see if it's blown. Verify the a/c relay is working by checking for 12v at the compressor when the a/c is turned on. If not then have the freon pressure verified by a shop if you don't have a gauge set. It may just be low enough not to allow the low pressure switch let the compressor run. if it is low then you have a slight leak somewhere which can USUALLY be taken care of with some freon mixed with leak sealer. If all that checks out and the compressor still doesn't cycle then you may have a dead compressor clutch.
Old 04-22-2006, 06:19 PM
ReD95LT1's Avatar
what fuse is for the ac?
Old 04-22-2006, 06:36 PM
ReD95LT1's Avatar
I just checked all my fuses and they are fine, but what about the relay, how can you check that out and can you buy one from say checker or auto zone?
Old 04-22-2006, 06:42 PM
Captainofiron's Avatar
I think Autozone checks relays. If not switch it with the relay for something that isnt a necessity. I changed mine with the Fog lights relay. Then check the connections on the hi pressure cut out switch. If all that is ok finally check out the A/c compressor clutch electrical connector. If it is out maybe that is your problem. if not then you have other problems. I am having trouble with my A/C right now too. I feel your pain buddy. Im in south texas right now, so its hot and humid, but I doubt as hot as it is in AZ
Old 04-22-2006, 08:39 PM
ReD95LT1's Avatar
yeah especially having to wear a tux in the car in mid afternoon, that sucked!
but i took it to checker, they put in a new relay, it didnt work so he just boxed it back up (never paid for it)
I bought some freon, he hooked up the hose and bam!
ICE COLD
So that was all it was! sweet
Old 04-23-2006, 10:09 AM
Smokinlt1's Avatar
Where did the old freon go? you've got a leak in your system somewhere, you need take it somewhere and have an A/C service done where they add dye so they can find the leak. Otherwise, you'll wind up having too charge the system again.
Old 04-23-2006, 10:16 AM
Smokinlt1's Avatar
It would relly sux to get in your car in the middle of July and not have A/C
Old 04-23-2006, 03:30 PM
ReD95LT1's Avatar
yeah there has to be a leak somewhere, where can i take it for cheap?
Old 04-23-2006, 05:48 PM
Talk to a commercial sales guy at a parts store that has a commercial department, they usually know who is cheap and who does a good job, there is a big difference.
Quick Reply: Air Conditioning broken in AZ!
