vomitcorpse
04-22-2006, 05:40 PM
i got a philips 42 inch plasma hdtv for sale.it's only been used for like a month,i have original box and everything that came with it.its practically brand new.i'm looking to get 1,700 out of it.this is the latest model from philips.at circuit city its for 2,300 plus tax,so you're saving a good amount of buck.i'll post pics tomorrow
Breathtaking natural pictures
High-definition plasma WXGA display, 1024x768p
Integrated HDTV and CableCARD for unrivalled picture quality
Enjoy HDTV that's truer than anything you've seen before
Pixel Plus for better details, depth and clarity
Progressive Scan for razor-sharp and flicker free images
Stylish design
Matching stand with elegant design included
One touch convenience
Plug & Play for easier installation
Access your digital content
USB Connector for easy, instant multimedia playing
Leading interface for digital quality audio/video
HDMI for full digital High Definition connection
full specs:
Picture/Display
Aspect ratio : 16:9
Brightness : 1500 cd/m²
Diagonal screen size (inch) : 42 inch
Diagonal screen size (metric) : 107 cm
Display screen type : HD Plasma panel
Picture enhancement : Pixel Plus, Progressive Scan, Active Control + Light sensor, 3/2 - 2/2 motion pull down, Widescreen Plus, 3D Combfilter, Contrast Plus
Screen enhancement : Anti ageing circuit, Anti-Reflection coated screen
Panel resolution : 1024 x 768p
Contrast ratio (typical) : 10000:1
Viewing angle : 160º (H) / 160º (V)
Supported Display Resolution
Computer formats : 640 x 480, 60Hz, 800 x 600, 60Hz, 1024 x 768, 60Hz, 1366 x 768, 60Hz
Video Formats : 640 x 480i - 1Fh, 640 x 480p - 2Fh, 720 x 576i - 1Fh, 720 x 576p - 2Fh, 1280 x 720p - 3Fh, 1920 x 1080i - 2Fh
Sound
Sound Enhancement : Smart Sound, Auto Volume Leveller, Digital Signal Processing, Dynamic Bass Enhancement, Graphic Equaliser
Output power (RMS) : 2 x 15W
Sound System : Virtual Dolby Digital
Loudspeakers
Built-in speakers : 2
Convenience
Ease of Installation : Autostore, PLL Digital Tuning, Plug & Play, Automatic Tuning System (ATS)
Ease of Use : On Screen Display, Side Control, Smart Picture Control, Channel list, Smart Sound Control, Delta Volume per preset
Remote control type : RC4345/01
Remote Control : Amp, DVD-R, Multi-functional, Sat, VCR, DVD
Screen Format Adjustments : 7 Widescreen Modes, Auto Format, Subtitle and Heading Shift
Child Protection : Child Lock+Parental Control
Picture in Picture : HDMI-Component PIP
Clock : Smart Clock
Teletext : Closed Captioning Full Text
Multimedia Applications
Digital Content Management : Digital Media Reader
Multimedia connections : USB memory class device
Playback Formats : JPEG Still pictures, MP3, Slideshow files (.alb)
Tuner/Reception/Transmission
TV system : ATSC, NTSC
Video Playback : NTSC
Aerial Input : 75 ohm F-type
Cable : Digital Cable Ready CableCARD, Unscrambled Digital Cable -QAM
Connectivity
Other connections : Cable Card Interface, Monitor out, CVBS, L/R (cinch), S/PDIF in (coaxial), S/PDIF out (coaxial)
AV 1 : Audio L/R in, CVBS in, RGB+H/V, S-Video Y/C, YPbPr, Component Video in, (1, 2, 3Fh autoranging), Y/C
AV 2 : Audio L/R in, CVBS, S-Video
AV 3 : S/PDIF digital coaxial, YPbPr, (1, 2, 3Fh autoranging)
AV 4 : HDMI
AV 5 : HDMI
Front / Side connections : Audio L/R in, CVBS in, Headphone out, S-Video in, USB 1.1
Power
Power consumption : 400 W
Standby power consumption : < 2 W
Mains power : AC 100 - 240 V, 50/60 Hz
Ambient temperature : +5 -/+ 40 C
Dimensions
Product dimension (WxDxH) inch : 4.1x26.8x48.8 inch
Product weight : 38 kg
Product weight (lb) : 92.6
Weight incl. Packaging : 55 kg
Set Width : 1240 mm
Set Height : 680 mm
Set Depth : 104 mm
Color cabinet : Pearl White Silver
VESA wall mount compatible : 800,400 mm
Accessories
Included Accessories : Table top stand
Stylish design
full specs:
Picture/Display
Aspect ratio : 16:9
Sound
Loudspeakers
Convenience
Clock : Smart Clock
Connectivity
AV 4 : HDMI
AV 5 : HDMI
Power
Dimensions
Set Width : 1240 mm
Set Height : 680 mm
Set Depth : 104 mm
Accessories
