fuddle 3600 stall
fuddle 3600 stall
i just installed a new fuddle 3600 stall 2.5 str,well when i push on the gas hard sounds like a grinding sound or like a swoosh noise only when you step on gas,does anyone or is this normal
i just tested and around 40 it locks up then you step on the brakes and you can see the rpms go up from 2000 to 2400 so it is working but possibly at higher speeds the computer is not letting it lock or something because the rpm are at 3000 at 70
Also the computer will not lock the TC until your transmission reaches a certian temp so if the problem is only in the first mile or two then that could be your problem.
