Will these rods work???
Building a 6.0 block with forged components. I'm staying with the stock crank and going with a larger bore and going FI. I want to make sure these will work before I buy them. I thought the price of $479 was a good deal. I called and he has more in stock for that price.
Decription:
Brand new in the box, A SET OF EAGLE 3D ESP H BEAM RODS, Each bid is for one complete set of rods, shipping on each set of rods is FREE. these rods fit the CHEVY SMALL BLOCK LS1 ENGINES, WITH A .927" WRIST PIN AND STOCK 6.1" LENGTH. perfect quality and bullet proof strength. no junk no seconds. these are part # crs6100L3d.
http://cgi.ebay.com/ebaymotors/ws/eB...875628572&rd=1
Decription:
8 SEC SLOPPY SHOT!!!
Re: Will these rods work???
I have 6.125 eagle rods with je pistons i have one season on them and pulled the pan to make sure every thing was fine bearing are like new i think the rods are priced well
Or should I get these:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2400465067
A SET OF 8 NEW CONNECTING RODS FOR THE SMALL BLOCK CHEVY EAGLE 3-D ESP RODS. 6.125" LENGTH. made of 4340 forged steel . arp 2000 rod bolts installed fit the stock CHEVY rod journals 2.100" pin cranks . BRONZE BUSHING FOR FULL FLOATER. THESE RODS ARE THE EAGLE 3-d esp featherweight rods. USE THESE RODS IN ENGINES THAT need light weight rods for the maximim advantage 550 grams the normal weight h beam rods are 660 grams. NEW!!!
Seams like they would work since they are a stock 6.125" length.
