problem with idle...help?
ok i posted this in internal but i didnt really get a response...so here i go, i have a 99 a4 ls1, when it warms up or if i drive it on the highway and get off and just drive around the oil pressure gauge jiggles...or ticks...take ur pick, i know its still in the good range at warm up...30-40, but it ticks and moves and when it does so the idle is kinda rough, i do need to change out my wires and plugs, id see how that would help an idle, but i dont see how that could effect the oil psi if that was it? oil pump?, think about it this way, u have the 20 mark then the 40 , make a line in between and call it 30, it ticks between 30-40 pretty easy, just didnt think it should move that much...any thoughts?
Either check your oil pressure with a separate gauge or replace your sending unit and see if you get the same result.
If you are getting thumping or slapping you may actually have low oil pressure. That is not a good situation. You may have a bad oil pump.
Good Luck!!
Good Luck!!
i just got my ported ls6 oil pump from TSP, it was like 160 ??? not sure on the price but it shouldn't matter either way, it needs to be done or you will be paying more for a blown engine being repaired if you plan on doing a cam or anything in the future, i definately recommend the ported ls6 too by the way.
Is the gauge ticking, the gauge may have a problem internally. I think its a good idea to check the engine out and check the actual oil pressure first, then proceed to the gauge and or sending unit.
