460le rebuild question
Old 04-23-2006, 12:57 PM
steez's Avatar
Default 460le rebuild question
im getting it rebuilt wiht a stall tranny cooler vette servo and MAYBE a shift kit....the reason my tranny blew in the T/A in the first place was cause of way to much line pressure, just wondering would it be safe to get a shift kit put in? or would i be breaking more ****
Old 04-23-2006, 01:07 PM
Camaro ChriSS's Avatar
Hi Steez.
I shift kit done right will better your tranny. It replaces a lot of the weak tranny parts that come stock with the car. You'd be amazed how crappy some of the components are. Guys usually run into problem if they try to bump up the firmness too much and get too aggressive with a kit. You can do as much harm as good, but most guys will tell you that used right, it will really improve the life of your tranny.
There's a good company that sells modified shift kits - something like Pro-Build Automatics. Dana is real knowledgable and his prices are good. A lot of guys like his work. That's what I have.
Only trouble is finding a good shop in our area to does this work.
Old 04-23-2006, 03:16 PM
steez's Avatar
ha ha hey chris! yeha i have done some research and decided to get a&b transmission to do it on the by-pass..im impressed guy knows his stuff....what kit would you recomend? a trans go?
Old 04-23-2006, 05:43 PM
Yes, transgo is very good. Likely the best. Check out that website I posted.
Old 04-24-2006, 05:58 PM
steez's Avatar
thanks buddie
Old 04-24-2006, 11:13 PM
But, its nice to get feedback from guys other than whom you already know, so if anyone else has any info to help Craig, please chime in!
See you on the road man.
