alternative to race gas?
Old 04-23-2006, 05:55 PM
violator3434's Avatar
Default alternative to race gas?
is there any other alternatives beside using race gas for nitrous?
Old 04-23-2006, 06:11 PM
Robert56's Avatar
Propane.
Robert
Old 04-23-2006, 09:11 PM
nothing from MSD ignition would work?
Old 04-27-2006, 02:36 PM
11 Second Truck Club
MPFD's Avatar
When E85 comes out there will be some people spraying 300hp on pump ethonal. The octane rating of ethanol is somewhere around 100. But the fuel comsumption will probable about double.
Old 04-27-2006, 04:21 PM
gnx7's Avatar
Xylene (117 octane)
Tuolene (114 octane)
3 gallons of Xylene
7 gallons of 92
3 ounces of Marvel Mystery Oil (MMO) for fuel lubricant
yields 100 octane
If you do:
3 gal Xylene
7 gallons of 100 octane
3 ounces MMO
yields 105 octane
Safe for cat convertors if you run them too! Don't go over 30% Xylene or cold start problems can occur. ie doesn't want to idle
Old 04-27-2006, 04:30 PM
7 Second Club
Phil99vette's Avatar
How about a fuel for a standalone fuel system that is only used for fuel enrichment? Can you run more xylene or toulene?
Old 04-27-2006, 05:09 PM
Restricted User
CAT3's Avatar
Phil, I was told you can, but there is a point of diminishing returns, and that no more than 50% is recommended, making sure the MMO isued for seal lube. I havent tried it yet, but would like to. Propain has a propane injection setup, which if you talk to the owner/tech they would sell you everything you needed to run it as the fuel side for a wet kit, rather then buying their kit and hacking pieces out of it, higher octane, however not legal for NHRA Tech.
Old 04-27-2006, 10:53 PM
KOS
KOS's Avatar
meth injection
Old 04-28-2006, 12:34 AM
Restricted User
CAT3's Avatar
Hmmm Matt from Snow was supposed to get back to me about hooking up a meth/nitrous system..this just reminded me. I have a friend with a 5.0 Fox that was going this route, which got my gears clinking, I chatted with Matt, but forgot all about that...time to get ahold of him.
