setting idle
setting idle
does anyone know how i can set my idle??? it idles around 900 and my car shakes a little, i have just replaced motor mounts, tranny mount, plugs, wires, and opti so its no miss or nething like that? i would just like to raise it alittle
yeah youll have to program your pcm again to do that, if its an M6 thats around where it should be, if its an auto then it should be 500~600. if you put in polyurethane mounts then your going to have a bit more shake then the rubber ones since theyre stiffer.
Originally Posted by djkyle25
no where is that located at??? and are the oxygen sensors connected directly to headers
Originally Posted by StealthFormula
Dunno where there located but Yes the 02's are connected directly to Long Tube headers. With stock headers I believe one is on the cat and one on the y-pipe somewhere. BTW What is the stock idle rpm??
If you must raise the idle, there might be a "screw" in which you can force the throttle blades to stay open. My BBK 58mm has one but cannot recall the stocker. Just screw it out towards the front of the car and it will open the blades slightly, like giving it pedal.
