help- price and gas mileage
im looking at buying this car and ill need to drive it everyday to school at to work ( 6-8) miles, would i be able to use it as a daily driver and what kind of gas milage would it get if i dont get on it. also howmuch would you pay for it
1996 camaro TRUE SS car #1519
forged 383 stroker motor, callies crank, je 8.5:1 pistons, clevite bearings.
small blower cam unsure of specs but trying to find the receipt, has stock heavily ported intake and heads. crower roller lifters and 1.6 crower roller rockersupgraded fuel system including new 255 gph inline pump and bigger injectors but not sure on size again i have to get the receipts for those.
Vortech S-trim with stock pulley 6lbs boost. a/c delete. also has a nice Vortech aftercooler. SLP full exhaust from midlength headers to loudmouth pipes. subframe connectors and adjustable torque armTh-400 trans built to handle 750HP, with more clutch packs (6) a shift kit, 3800 9.5" stall and transbrakecustom driveshaft i think its 4"-5" diameter. corbeau racing seats
446 hp 502 torque
446 hp 502 torque
I'll say this if it has all those mods the gas mileage will not be very good. hint TH400 3800 stall Plus it has no A/C
You have to tell yourself do I want a race car? or Street car? That car may be streetable, but it will suck as a daily driver it's more of a race car or weekend warrior "street" machine.
If you are short on funds don't buy this thing as your only car. You will soon hate it.
Not too much of the original SS left! I am asking myself why you are even considering this car? It sounds like a nightmare.
Use as DD? NO!
Mileage? 10-14. When it is running. Ha Ha (you will need another car to drive when this one is broke down).
A price? The trans & engine are worth 5-7k used and abused. Is the paint perfect? Hows the interior? with answers of fair and fair 5 for the car no drivetrain.
IMHO Pass. Better yet, RUN!
Use as DD? NO!
id probably pass, in my honest opinion that car isnt making very much power for the mods that are done to. i mean hes got a forged out low compressoin 383 w/ a blower and only putting 446 at the wheels? i might be wrong but i would expect a little more out of a car with all of that and no A/C. just my 2cents.
Definitely not a car I'd rely on as a daily driver.
The power seems pretty low for a blown stroker. Anyone else notice that?
My 385 LT4 put down 432/468 NA through a 12 bolt and a billingsley extreme driveshaft.
Might be a nice car, however. Not enough info to determine that. But there's enough info to determine it would not make a good daily driver.
Originally Posted by BlueSix
Those numbers are through a TH400 and probably an unlocked converter. I wouldn't say the car "isn't making very much power..."
Whoops, didn't see your post before I entered mine. I'd disagree with you too. I'd expect a well made stroker with 6 psi to be hitting 500 RWHP.
The car in question is only putting out 14 more RWHP than my UNBLOWN stroker, that dyno'd through a 4L60E with a loose 10.5 inch 'verter unlocked, a heavy steel DS, a Strange 12 bolt, and... FWIW heavy OEM wheels (more rotating mass).
