converter question/problem
Old 04-24-2006, 11:16 AM
TwoFast's Avatar
Default converter question/problem
Ever since I installed my 3000 stall converter, it unlocks and locks on the highway about every few minutes or so. The trans shifts fine and everything. Its just when I'm driving down the highway at around 60-70 it will stay locked, but every now and then it will unlock for a few minutes and then lock right back up. I know the converter isn't bad because I bought it from a guy that said its in excellent shape and didn't have very many miles on it. could it be a lock up tuning issue. could I have my tuner change the lock up points or something? thanks
Old 04-24-2006, 11:52 AM
GDM Z28's Avatar
mine is doing the same freaking thing....its either the converter, TCC, or valve body.
Old 04-24-2006, 05:27 PM
2sigmans's Avatar
My viglante 2800 in my vette is also doing the same thing! I was told to look at the misfire file and either turn it off, or raise the thresholds. Going back to the tuner on weds and I'll let you know how it works out.
Old 04-24-2006, 06:04 PM
TwoFast's Avatar
let me know if you guys find anything out. thanks
Old 04-24-2006, 11:50 PM
GDM Z28's Avatar
i was also told it could be because of missfire and i thought it was picking up my cam as missfire (sometimes i throw i random cyl missfire). tonight i added more line pressure with hp tuners and after driving aorund for 30-35 mins it didnt do it....for some odd reason it might of fixed it.
Old 04-25-2006, 09:31 AM
jmm98LS1's Avatar
If the pcm detects any misfires it will not allow the converter to lock. If you're right on the bubble with allowable number of misfires, I can see it locking/unlocking the converter. That'd be the first thing I'd check.
Old 04-25-2006, 10:22 AM
GDM Z28's Avatar
im not throwing any miss fire codes so i do not believe thats what was happening with my car. but my 02 sensors are dead so it might of been acting up. ever since i played with hp tuners it hasnt been doing that. just food for thought.
Old 04-25-2006, 09:27 PM
TwoFast's Avatar
yeah I think my front o2 sensors are going bad, could that be causing the problem?
Old 04-29-2006, 05:57 AM
2sigmans's Avatar
O.K. We adjusted the misfire tables to 32000 as jimmyblue suggested, and that fixed the problem. Thanks for the advice jimmyblue!
Old 04-29-2006, 06:18 PM
Muerte_X's Avatar
I had this problem recently, although not the entire time I've had the converter in. I took out my TR55's that had maybe 15-20k on them, and they're were done. Tossed some new ones in and it's perfect again.
Just thought I'd add that in there as something to check. It also didn't throw an SES light, even though I'm sure it was misfiring a little with the tired plugs.
Old 05-01-2006, 09:38 PM
TwoFast's Avatar
I replaced my front o2 sensors and the ses light went away after 2 days, but the converter still does what I described in my first post. Any suggestions? I'm going to see my tuner in the next day or so, so I'm looking for some ideas to throw at him, and see if we can get this tuned out. thanks
Old 05-04-2006, 09:55 PM
LT1WS6TA's Avatar
my fuddle 3400 is also doing this would like to know how to correct it to
-thanks
