99 Clutch Help
99 Clutch Help
About a month ago we replaced the clutch in a 99 Vette with a Spec 3 and used a new GM slave cyl. The instructions with the Spec 3 said not to use the spacer supplied on Vette applications. Now occasionally the pedal is sticking to the floor on WOT shifts. Is the fix for this a new master cyl? Will a new GM master be an upgrade from the stock 99 master on the car now and likely fix this issue, or is an aftermarket adjustable needed? Also, does GM use the restrictor in the line on Vettes like they do on the F-body masters.
