Calling all A/C Experts!
The previous owner of my 00 trans am remove the a/c lines and compressor. I really would like to get a/c working again, and I know its going to be a long expensive trip back to it due to likely contamination. (He didn't block any of the ports)
What are the things that absolutely must be replaced, what things can be checked, and what can be saved?
Anyone try this before?
Hmm, noone work on their a.c? How about some pics of the a/c lines, I'm not sure I even have all the lines, particularly the line that somes from the firewall (evap) over to the condensor.
Obviously you are going to need a new/rebuilt compressor, lines and accumulator. Also get an orifice tube, pressure switch and assorted O-rings, nuts, bolts etc. You can probably get a GM kit at your ac supply place. Try to avoid the dealer$$$
I would get a new evaporator and condenser along with the rest.
You might get away with flushing the the old evap, but I don't think the condenser can be flushed properly.
It really is best just to bite the bullet and buy new stuff.
You're going to need some gauges and a vacuum pump.
I will be expensive but worth it in the long run. You will add 2k to resale at least.
I hate it when some kid takes the AC off his "race" car
Well, it depends on how much stuff you got left. You can reuse the lines. Go aftermarket on the accumulator, condenser and get a rebuilt compressor. You can find damn near all of it at a local parts store especially the small stuff like O-rings, orifice tube and switches.
Inventory what you got.
Price what you need.
Stay away from the dealer if possible.
Buy a cheap set of gauges and rent a vacuum pump.
Originally Posted by Armageddon
I've got an entire system for sale for $200+S/H. Compressor, Condensor, Accummulator, all lines... everything. PM me.
Originally Posted by tcossair
Do you think the compressor would be bad by sitting in a closet in his house?
Edit.
I would stay away from a used condenser too, probably packed with metal bits after the compressor let go. Do it once, do it right.
Its a low mileage car, 53k, and he removed it when he installed LT headers because it "got in his way" along with the usual weight savings crap. Grr..
I definately will replace the accumulator. (How do they seal those when you buy them to begin with anyway?)
Use the lines, flush the evap and I'm not sure about the condenser on these cars but you can google to find out if they can be flushed. Spin the compressor make sure it sucks and blows put it together and pull a vacuum the longer the better. Overnight is great! Then see if it works. As long as you have all the parts, match up what you can afford and buy those components new. Ac systems don't like to be left "open"
Thanks for the great info. Don't happen to have any pics of the engine bay showing how the lines go do you?
Edit
There are filter kits you can place in the lines to catch any metal it might be tossing around since you are using used stuff look into one. Good insurance.
I'm starting to think I'm missing a piece that goes into the top line of the condensor. I spent the afternon trying to piece it together for reference. I'll probably have to go checkout a trans am on the lot somewhere at a dealer to be sure.
I think my used compressor is already dry (do you drain it by just turning it upside down) so I'll have to figure all that later.
Want to come to indiana and help out lol? :-)
Shirley Temple Drinker
2k to the resale? VERY doubtful it would ad even 1k. And there are many reasons to take AC off, one would be to de-clutter the bay, also the whole system weights 50lb's, which is halfway to another 10th in the 1/4. I'm gonna rip my **** out soon, I can't wait to get it out of there, I just tried using it for the first time, b/c I didn't wanna take the time to take my t-tops off of it, and it worked for like 10 mins, then went hot. Why spend 200 bucks or more to have a "comfort" option? Screw A/C Only reason why I would have it would be if I lived in like AZ or TX or something.
Edit...
Just try and see how much of a hit you take on resale with a car that's A/C don't work down here You're building a race car not everyone in the F-body community is doing that some of us like fast comfortable daily driver.
Place the compressor over a measuring cup a turn the clutch and pulley together and see how much oil comes out the discharge side. Don't worry if you don't see any it is just a good reference point.
Sorry man in Texas
I live in Texas Have fun.
Edit...
Edit...
Im not building a race car just yet, I daily drive my car. So far its been 80 and muggy and I would still rather have the sun beating in on me b/c I've got my tops off than A/c But it at most gets 105 and muggy as **** here, so its not that bad I guess.. I seem to have come off a little strong, I just seen that comment and took that as calling everyone that yanked their air a ricer..
