Will my stock DS survive the track this friday night?
Old 04-24-2006, 06:52 PM
98TADRIVER's Avatar
Default Will my stock DS survive the track this friday night?
mods in sig. im curious here- do u think its safe for me to run at the track as long as i dont dump the clutch at 5k rpm? The DS held up the last time i went to the track, because i wound up breaking my 10 bolt (on street tires)
i slipped the clutch quickly around 4000 RPM, it got me off the line quick on my street tires and stock gears.
This time i will have a 9inch, 4.11s and MT DRs.
Old 04-24-2006, 06:58 PM
98_1LE's Avatar
It will survive with no problems.
Old 04-24-2006, 07:31 PM
98TADRIVER's Avatar
cooool anyone else's opinions?
Old 04-24-2006, 09:00 PM
ls2 bait's Avatar
good luck. ive seen them break several times on a nitto. (actually 3) but ive also seen one handle a 6k dump on an et drag.
Old 04-24-2006, 09:09 PM
98TADRIVER's Avatar
maybe i will just use my street tires? lol
Old 04-24-2006, 09:46 PM
Orange99Z's Avatar
I've dumped the clutch at 6k with the stock DS and E/T Streets a few times. I take a spare to the track with me and I'm looking to get a new steel one. Mods in sig.
Old 04-25-2006, 12:58 AM
Z95m6's Avatar
I have a stock steel one out of my LT1 it just needs a front yoke installed on it. I took my LT1 Yoke off it and installed it on my LS1 shaft, i still have the LS1 yoke too. It would be a lot cheaper than breaking your nice Aluminum one and replacing it. If you're interested just let me know.
Old 04-25-2006, 03:35 PM
ls14jay's Avatar
I say it has no chance.(see pic in sig) Mine went out at a gentle 3000 rpm launch first time out with drag radials on stock rear, on a supposed terribly prepped track..
Expensive tow bill that night.
Jay
Old 04-25-2006, 03:40 PM
Old Geezer's Avatar
Question And....
Jay
Jay, You were lucky, that was all that it cost.
I'm .
Lots of bucks spent on a 9", yadda, yadda, and then, take a chance on finding the DS sticking up your ***, and the car in the wall????
Got a d/s loop? You just may find out if it works....
GOOD LUCK..
Old 04-25-2006, 04:26 PM
ls14jay's Avatar
I'm very thankful I went ahead and put on a DS loop the day before I went racing.My shaft broke instantly,the car maybe made it an inch down the track which was lucky,and saved me a pair of underwear.
On a side note, I have noticed some small puddles of tranny fluid lately.Haven't jacked it up to check it out yet,but would assume that I damaged the seal when it broke.
Jay
Old 04-25-2006, 09:41 PM
mike#9's Avatar
Jay
I see nothing wrong with that driveshaft....it is shortened for a aftermarket rear right??
Old 04-25-2006, 10:57 PM
Racer8102's Avatar
I don't think you will have any problems, if so you needed to upgrade anyways.
Old 04-27-2006, 05:04 PM
ohsofast's Avatar
I have seen stock cars break there DS, but they were probably the exception. I pull high 1.6 60 foot (I do it alot) and still got the stocker.
Old 04-27-2006, 05:32 PM
98TADRIVER's Avatar
cooool. and yes i do have a DS loop!! and i hope i dont have to find out how good it is
Old 04-27-2006, 07:11 PM
SPEEDYws6's Avatar
It's your car do what you want, but if the car hooks and you have a good clutch it shouldn't last more than 6 passes at a 5k dump. I went to the track several times on my stocker, and ran the times in sig, but I never dumped it. I don't care about breaking my DS, but I don't want to run the risk of output shaft damage, which is pretty common when the DS goes.
Old 04-29-2006, 12:01 PM
EPP
EPP's Avatar
I broke a Lingenfelter 3.5" aluminum driveshaft on the starting line on a lousy hooking track. The car did not even trip the staging lights... The driveshaft broke at the 1330 yoke end. I was only making 540 rwhp with ET streets.
I have since upgraded to a PST 3.5" aluminum driveshaft, which is much stronger and uses a 1350 yoke, which also means no hybrid U Joint has to be used. The PST shaft is rated at 1200 hp, and comes with both U Joints for $399.99. I highly recommend it. Bob
Old 04-30-2006, 11:24 PM
Jimmard's Avatar
That's what I'll be using eventually.
