Valvespring question
does anyone know the max lift for the valvesprings that come with the LT4 hotcam kit? i know that the rockers that come with kit are rated at a max lift of .575". are the springs the same?
thanks, anthony
thanks, anthony
not to hijack your thread, but if they're good up to .540 lift, then that means my lt4 heads with the lt4 kit springs should hold up to a cc306 and a 847? i already have 1.6rr's
There is a lot more to what a spring can handle than what lift it is safe too before bind.
The LT4 springs are marginal for the HOT cams .525 lift and mild lobes running it on a smaller cam with more aggressive lobes would be a lesson in what valve float feels/sounds like much less trying to put them on a bigger cam.
I checked this out a long time ago.
Jim
