Plugs and Wires
plugs are kinda a pain in the *** the first time around. get plug 8(back passenger) from under the car, its easy that way. Dont forget some dielectric goo for the plug wire boots.
Don't forget antiseize for the plug threads. If you don't then the next time you change plugs they might not come out. I just changed my plugs the fourth time on Sat along with new wires. I used tr55's and Msd wires. Be sure the plugs are tight. After I was done and started the car it would surge and miss then I pushed on the plug wires again and the problem went away. Put the wires on the coil first then the plug. I have lots of small nicks all over my left arm.
