Air Temperature Module
Are any of you running this? I saw it on AfterThoughts Auto. they say you gain 5 to 7 hp, which isn't much but every little bit helps, right?
it advances timing i believe. i used a 4.7Kohm resistor i belive it was, a cheap cheap resistor from radioshack. just plug it into the plug where the IAT sensor used to be tricks the computer into thinking it is 55-57 degrees constantly.some people say that when the outside temp gets too hot, your car might ping from too much timing, but personally i have never had any trouble. you can try it to see what you think of it and always plug your stock sensor back in
