sorry,ford 351 stroker question
i tried to post on corral.net but the f*ckers wont let me post.anyway,if this gets moved let it run as long as possible.i may put ford motor in my mach1 instead of ls1.if i do should i go 408 or 427 stroker from 351 windsor?i am so used to the easy power from lsx engines and i want a ford motor that runs pretty decent around 400rear horses. I know but i think some of you guys are more knowledgable than most of the ford guys.plus they are mostly ****** that wonder why people should not mortgage their kids to run with ls1.
Maybe I shouldn't post this here, but I've built a bunch of ford stuff. I can answer your questions. Give me a call 512-257-0222, we just finished an all alumnium small block 427 ford with an efi system. It should be good for 650 to 700 HP.
The cubic inches you want will depend on which block you have. Anyway the advise is free.
Ask for Harold
