? about putting a little spray on top of a blower car.
I have a C5 with a D1SC at 9psi, tunned very rich at 10.5 degrees of timing at wot,60lb injectors,kb bap, and was thinking of putting a 50 shot on it just to help it out down low. Should it be okay?
I ran a 50 dry shot on a P1SC car but I had the MAF recalibrated where it would read at 8psi + the 50 shot and it worked very well. 1/2 a second and 5mph in the 1/4 or so. Putting a 50-75 wet shot on it should be no problem as long as your fuel system will keep up. I would be very careful and keep it rich if you have stock pistons though..
Jeez, I'm running 7.5# at 24 degrees advance and 12.2 AFR. Yours seems too conservative, unless you are knocking all the time. My CR is 9.66:1.
Like brad said... but I think you should get a better tune before you add it. That is what I would call a lazy shop tune - make it work, make it safe, but no optimization.
If you add a shot, think about a MSD retard box that only is active when you are spraying. I use the MSD Multi-Step Retard tied to the NOS solenoids. I like to stick with the NOS recommendation of 2 degrees pulled out for every 50HP in nitrous. AFR target on spray of about 11.5:1.
Jim
My Site: http://home.mindspring.com/~jim_fisk/id1.html
Jim
I had the scan tool hooked up and at wot the timing was at 10.5 degres, yes they tunned it safe and yes im am not to happy when i found that out, safe is one thing, choking it out is another. It is kind of laggy down low and that is why i wanted to do this.
So can i just tune it to say 15 deg. at wot and not have to play with the fuel curves, because i can get that done. I dont want to pay another $180 for throwing it on the dyno.
You don't have to worry about 'fuel curves' if all you are concerned about is WOT. If that's the case, dial in a sane (11-12) AFR and make sure you don't have any KR. Even then, I'd recommend you check it on a dyno. When I first dyno'd my car my commanded AFR was 12.1x, but my actual AFR was 13.6x. Not good
My opinion? Spend the money and get a good tune. Unless you add more parts, the tune won't go 'bad'.
It already has a good tune mius the timing issue, it was on the dyno for about 2 hours getting pretty damn good and safe, just want more timing so i can wake it up a tad where its lazy.
For the timing, you need to find out what it's running versus the commanded timing. If you are running less than commanded then something's pulling timing on you (heat, KR, etc). If everything is fine, bump your WOT timing in increments of 2* until you see knock, and then back off.
