Switching intakes
Old 04-25-2006, 01:58 PM
brokez's Avatar
Default Switching intakes
Got a freind that's going to let me take his ls6 and he's going to take my ls1.Can't just switch the coolant pipes from his to mine and the ls1 **** to his.Then I would only need to but the intake gaskets right
Old 04-25-2006, 02:35 PM
conan's Avatar
Yes switch the 2 plugs in the back of the heads and the front crossover pipe. Replacing the gaskets is a good idea too.
Old 04-25-2006, 02:41 PM
brokez's Avatar
Then just put all the lines that were under my intake on his side and bolt up the ls1 intake and thats it? Thanks for the help
Old 04-25-2006, 02:47 PM
conan's Avatar
You got it.
Old 04-25-2006, 03:00 PM
brokez's Avatar
OK last question I promise Will his throttle body be any better than mine it's totaled so might as well get all I can
Old 04-25-2006, 04:23 PM
mattsls1's Avatar
tb's should be the same.
Also you will need a tune after switching intakes. When I switched to the ls6 my a/f went from 12.9:1 to 15.0:1
