Small Block & Big Block Chevy Specific - How much N/A power would this make?
1FSTZ71
04-25-2006, 03:31 PM
This is my new motor setup, and I'm trying to figure out how much power it'll make without the blower.
350ci-stock bore 4-bolt block
5.7 H-beam rods
SCAT 3.480 stroke Crank
GMPP HD Timing Chain
COMP Cams 220/232 duration .524/.534 lift w/1.6 rocker(1.52=.498/.507)
Stock Vortec Heads
1.6 Magnum Roller Rockers
COMP Cams 10309-1 Valve springs/retainers
Screw-in 3/8 studs
ARP Head/Main Studs
Marine Vortec intake manifold with 42lb injectors
1in TB Spacer
Gibson Headers, ORY, no-cats, Flowmaster 40 series muffler
MSD 6-offroad ignition with blaster 2 coil, wires/cap/rotor
NGK TR6 plugs
Any ideas? The stock engine was rated at 255hp 330 ft/lbs with 19lb injectors, stock cam, intake etc. I'll be running 8-9psi on it afterwards but trying to figure out the N/A power range. If it makes 315HP at the flywheel (should be more than that lol), according to a boost-HP increase calculator it shows 507.91HP after 9psi. Not sure if it's any where near accurate, considering 9psi would be netting a 190HP increase over it's NA power lol. Just hoping for 500+bhp @9psi before nitrous
1FSTZ71
04-25-2006, 08:26 PM
anyone?
TwoFast4Lv
04-25-2006, 09:30 PM
your heads will be the limiting factor ;)
Unported 300-330ish rwhp?
Villain281H
04-25-2006, 09:46 PM
Agreed the heads are the choker of the combo. 350-375 fwhp?
1FSTZ71
04-26-2006, 01:10 PM
Ya I was thinking somewhere in the mid to high 3's NA. I'm gonna either get a set of the 200cc Vortec's from GMPP or the new AFR Vortec's, but I like having the iron heads under nitrous+boost, just personal preference. I think under 9psi it should make around 500fwhp. CHP had an engine they were testing (Spot the Dyno Mutt lol). It had Vortec heads, upgraded springs, 1.52 rockers, .509/.525 222/230 114 LSA cam (pretty similar to mine), Dual-plane air gap intake, 650cfm holley modified for blow-through. N/A made 403HP, and 8psi made 558HP. Thanks for the help.
YenkoST
04-26-2006, 05:33 PM
Using that cam, I would say around ~400 just because its more of a FI cam then NA. However, compression is going to make a difference of those numbers as well, less compression=less hp NA. Also, what supercharger will you be running? Whose going to tune that engine?
1FSTZ71
04-26-2006, 05:41 PM
Still searching for a tuner to use my tunercat software. I don't know anyone locally who can use the Tunercat stuff, as of right now it's the ONLY tuner available for our Vortec computers. I have tuned it myself for the most recent 6psi on stock engine and I have it running pretty good. But Cam changes etc will need alot more altering than what I'm familiar with. I Have a Powerdyne BD11-A on it right now, plan on leaving it at 9psi when I'm done and just using the nitrous when I'm at the track. The CR of my engine would be around 10.4:1 after boost with the compression I am runnning with the new pistons. I don't see why it can't make 500fwhp on 9psi
YenkoST
04-26-2006, 05:45 PM
Do you have an intercooler for that 10.4 compression and 9 psi if you don't......then your short block will be short lived. Most run 9.5 at the most on a FI engine. There is a place in Jacksonville, Fl that tunes but don't know if they know the tunercat software....here is there website so you can ask them....http://www.dynotuneperformance.com/
1FSTZ71
04-26-2006, 05:55 PM
10.4 AFTER boost is less than what I am at now with 6psi. I am running 10.68CR AFTER boost, 9.0:1 before boost now. My new engine is 8.23:1 before boost + 9psi=10.42 after boost, still not requiring an intercooler and 93 octane friendly :)
andereck
04-26-2006, 06:21 PM
350-360 if everything is right. You can't expect the cam to do anymore than that. Done by 5500.
1FSTZ71
04-26-2006, 07:44 PM
the RPM range is shown to 6200 according to the specs
YenkoST
04-26-2006, 08:12 PM
Ok....got ya....didn't see the after boost part.....sometimes speed reading gets the best of ya. Sounds about right man....with the 8.23 compression NA, I would now say ~360 fwhp and about ~500 fwhp with boost. I would put an intercooler on it though so you could run more boost. :)
The tune will determine how much power you will be producing.
The only problem with 6200 rpms is that the computer won't let the engine rev past 5800 rpms.
andereck
04-26-2006, 08:21 PM
It may rev 6200 rpm, but it won't peak there. 220 @ .050" is gonna be done around 5500. The blower may take it a bit higher.
TwoFast4Lv
04-27-2006, 12:28 AM
I have personaly got dyno sheets that say that cam will peak at 6,100 or so ;)
How you doing with TC? I know some were having issues. I am STILL waiting for mondox to get there crap together :(
andereck
04-27-2006, 12:33 AM
I have experience that says it won't. But that doesn't count for much on an internet forum. Just trying to lay it out as it really is. Take the info for what its worth.
1FSTZ71
04-29-2006, 10:17 PM
ya I'm waiting on monodax too, TC just sold out to JET though :( it's a 220/232 cam, should work well under boost up to around 6K though
1FSTZ71
04-29-2006, 10:18 PM
how about with a set of AFR 195's, then add about 16psi of boost hehe might go TT on my Trans Am project instead of the truck
YenkoST
04-30-2006, 12:21 AM
Yep.....should be a nice piece, just can't rev past 5800 with stock computer system.
YenkoST
04-30-2006, 12:22 AM
I love my AFRs.
YenkoST
04-30-2006, 12:32 AM
I found this article for ya....maybe it will help.....440hp with unported vortec heads.
http://carcraft.com/techarticles/81998/
1FSTZ71
04-30-2006, 10:22 AM
lol I JUST found that article too haha. My factory computer won't go past 5600K unless I modify it with the tune lol. Shifts at 5.
YenkoST
04-30-2006, 10:02 PM
Yea....the computer can't go past 5800 even with tuning....it cuts the fuel or the ignition one....nobody has been able to solve the problem yet except for going stand alone controller.
1FSTZ71
04-30-2006, 10:57 PM
hhhmm, my TC system allows me to change the cutoff point
Bader-X
05-01-2006, 01:32 AM
is it a tbi system?
if so even if you use the holley upgrade a doubt it will reach 500 rwhp I don`t think they can feed aroung 560 flywheel HP!
just an opinion of a novice but might be worth looking up if it`s a tbi.
1FSTZ71
05-01-2006, 06:22 AM
is it a tbi system?
nope, MPFI like LT1/LS1
YenkoST
05-01-2006, 03:44 PM
1FSTZ71;
PM James B. on www.performancetrucks.net .....he has a vortec engine with the marine intake and hasn't been able to go past 5800 with his truck yet with a whipple...just a thought that would let you talk to somebody who knows through experience.
