Sponsored by: DashLynx
Clear lenses
Old 04-25-2006, 07:09 PM
rippenhard's Avatar
Default Clear lenses
Hey guys I was curious to how hard it is to install the clear corner lenses and whats involved in doing it. I would look for myself but I am seperated from my car right now because I am stationed in Germany. I should be getting stationed in fort sill in july so its all good. Back home for me!!!! Anyways thanks for the help.
Old 04-25-2006, 07:24 PM
H8 LUZN's Avatar
not too hard.. just pull the headlight and go to work
They will be a TIGHT fit going in (on the edges.. you'll see what i mean) but not to big of a deal. Takes 30 mins or so if you take your time.
Old 04-25-2006, 07:38 PM
LS69TA's Avatar
Mine were a b*tch on my Camaro. I almost cracked one of them trying to get it to go in.
Old 04-25-2006, 08:32 PM
CJDZ24_Z28's Avatar
Took me 30 min. Jacked the car up(just so i didnt have to lay on the ground) and removed the plastic panels. If i remember right the bolts are 9mm. There are 3 of them in each lense. No sweat
Old 04-25-2006, 10:15 PM
phantomzer0's Avatar
yeah and if you buy them dont forget to rtv the **** out of them, they WILL leak and get moisture, then you have to buy another set or constantly play with them. good luck
Old 04-25-2006, 10:17 PM
Ell Ess Won's Avatar
If you passed 9th grade you should be ok lol.
Quick Reply: Clear lenses
