What else todo for power on my Lt1?
Bored so I thought i'd ask what else todo to my LT1 to get alittle more power out of it? I know I can spray it car up in DFW area is doing 150-200.. but what other things can I do for alittle more hp??
Engine:
355 cubic inch shortblock
.030” over TRW flat top pistons
36lb Ford Racing Injectors (really 40lb in actuality)
ARP main studs & rod bolts
Comp Cams Xtreme energy 290HR-12 Cam (230/244)
Stage 2 ported heads by Lloyd Elliot
PCM w/ LT4 Knock Sensor Street Tuned by Moe (Texas Tuner)
MSD Wires
NGK T55 Spark Plugs
Oversized valves, titanium retainers, dual valve springs, etc
Ported LT1 intake
Meziere Electric Water Pump w/ HyperTech 160' Stat
MSD Cap + Rotor - Vented Optispark
LG Motorsports “G2” throttlebody airfoil & anodized cover plate
Flow numbers as follows:
Lift Intake Exhaust
0.050 35.8 28.4
0.100 65.9 53.3
0.150 103.9 76.3
0.200 132.9 105.4
0.250 160.2 128.2
0.300 189.3 145.4
0.350 213.1 155.9
0.400 234.9 167.3
0.450 248.6 175.7
0.500 258.4 182.2
0.550 267.2 186.9
0.600 271.7 190.5
0.650 272.5 192.9
0.700 268.3 194.9
Max. 272.3 194.9
Avg. 194.5 141.7
Exhaust:
Hooker longtube headers, ceramic coated
Off-road y-pipe
Borla catback exhaust
Engine:
MSD Wires
NGK T55 Spark Plugs
Ported LT1 intake
Lift Intake Exhaust
0.050 35.8 28.4
0.100 65.9 53.3
0.150 103.9 76.3
0.200 132.9 105.4
0.250 160.2 128.2
0.300 189.3 145.4
0.350 213.1 155.9
0.400 234.9 167.3
0.450 248.6 175.7
0.500 258.4 182.2
0.550 267.2 186.9
0.600 271.7 190.5
0.650 272.5 192.9
0.700 268.3 194.9
Max. 272.3 194.9
Avg. 194.5 141.7
Exhaust:
Off-road y-pipe
K&N AIR FILTER BABY!!! haha just kidding. From the looks of it, it doesn't seem like there is much more you can do. I would love to see what that thing can do!
oh so much is left on the table N/A...if you got the money....18* heads, solid roller cam, victor intake, etc...but that would pretty much elminate daily driving, i just get off on talking about a top end package that looks like that. You could swap cams to a blower friendly/turbo friendly custom grind, and force feed it whatever your bottom-end/tune/fuel system can handle. Or spray a nice 200 shot on top of it, again depending on your bottom end/fuel system.
Well what about this... says (and no I dont always believe these sites) should give around 10-12 hp on the Lt1? http://www.ws6project.com/user_stor/...ddfb82174a2dd6
you've pretty much got every bolt on covered, if i were you i'd start with some cheap weight reduction, less weight = faster lol. I just bought an AC delete pulley off of ebay, I'm looking forward to installing it this weekend. just food for thought
with A/c taken off I can still have air blown through the vents right and the heat for winter will work aswell?? because my a/c compressor doesnt even work I think (has a leak to i believe)
Sounds like you still need some 1.6 RR's, race ported intake, and dyno tune. The power pulleys are also a good idea, with a light weight Fuidampner, and an Aluminum Flywheel to free up some power that is being used up or robbed. Royal purple to replace all the fluids (motor, trans, diff) and that with also gain you a minute amount. good luck.
