Drag Racing Tech
Strange brake weight savings
Old 04-26-2006, 06:58 PM
30thz's Avatar
Default Strange brake weight savings
Strange drag brakes..................35.8 lbs
Stock LT1 brakes......................86.4
Total savings...........................50.6 lbs
And they look PIMP
Old 04-26-2006, 09:51 PM
theblur98ss's Avatar
Was that just the fronts?
Old 04-26-2006, 09:54 PM
Z284thgen's Avatar
anything i need to be on the look out for i get mine tomm and when i get back home from baton rouge i will be putting them on the car....
Old 04-27-2006, 07:17 AM
30thz's Avatar
A couple of good sharp sawzall blades, and the caliper mount bolts are easy to strip take your time.
Front only
Old 04-27-2006, 07:26 AM
Z284thgen's Avatar
do i dare ask why you need sazall blades
Old 04-27-2006, 08:37 AM
Racer8102's Avatar
I know on the LS1 cars you have to trim the edge of your spindle mount off so that the new strange spindle can sit flush. I got after it with a grinder, more weight savings!
Old 04-27-2006, 08:44 AM
30thz's Avatar
You need to remove the ears that mount the stock caliper and also shave the lower a arm (1/4- 1/2 in) to clear the rotors.
Old 04-27-2006, 11:20 AM
Z284thgen's Avatar
i thought that the fronts came with there own spindle's i guess i will find out here in a few when ups drop mine off
and i wonder if i will have to clearance the lower BMR tub a-arms
Old 04-27-2006, 11:38 AM
DopeFedZ's Avatar
I think they come with their own hub. Spindles are like $1000.
Old 04-27-2006, 03:40 PM
ninetres's Avatar
^^^lol, great fackin sig lol
Old 04-27-2006, 06:41 PM
phoenix's Avatar
are you useing these on the street?
Old 04-27-2006, 08:21 PM
30thz's Avatar
The only time I plan on driving on the street is to the local Track (5 minutes away) and local shows.
Old 05-03-2006, 11:22 AM
ninetres's Avatar
Link for sponsor to purchase? Or PM me where you got them.....and a price too as I am starting to save for these.
Thanks In Advance!
Old 05-03-2006, 12:09 PM
DopeFedZ's Avatar
Billingsley Racing>>>
SJM>>>
Old 05-03-2006, 12:33 PM
Bitemark46's Avatar
What size are those rotors? Does Strange recommend NOT for daily driving? -Mark
Old 05-03-2006, 02:32 PM
Old Drag Racer
Smokinstorm's Avatar
I've talked to Billingsley and SJM about these brakes and the consensus was that they'll stop on the street fine........once. It's the repeated braking thing that will cause problems and brake fade. As long as there's a cool down period between braking events I cannot imagine there being a problem on the street even though they're not recommended for street applications. They're going on the front of my 2000 SS as soon as funds permit. Along with some Bogart Welded R/T rims and skinnines. Like 30thz, though, my car is kept only a few miles from the track and will not be driven around joy riding.
BTW, SJM has a package deal on brakes and rims that's a killer deal for those interested.
Old 05-03-2006, 03:39 PM
ninetres's Avatar
SJM>>>
gracias
Old 05-03-2006, 04:37 PM
PewterZ28's Avatar
I assume this is for an LT1, right?
I've been waiting for someone to make a lightweight spindle for the LS1.
Old 05-03-2006, 05:09 PM
SScam68's Avatar
AJE makes them and I believe Mark Williams but I'm not sure on that.
There is a member running the AJE front end setup. Run a search in this section.
Old 05-03-2006, 06:45 PM
DopeFedZ's Avatar
Go to this member's photobucket account. He has pics of his spindles.
http://s37.photobucket.com/albums/e83/juicedws6/
Quick Reply: Strange brake weight savings
