Before I spend the money - please advise?
Old 04-26-2006, 10:33 PM
DFWGrant's Avatar
Default Before I spend the money - please advise?
I'm going to buy a 10-bolt from an 01 TA that was an m6 - it's a series 3 (3:42's) no TCS. I can drop my rear end (99 z28, auto 2 series channels) and it will bolt in, right? I can use my own brakes? Can I use my own driveshaft?
Thanks!
Grant
Old 04-26-2006, 10:43 PM
Carter Hays's Avatar
Yes as long as you got 3/channel abs everything will work. I don't know what 2 series channels are
Old 04-27-2006, 01:17 AM
DFWGrant's Avatar
I have the stock brake system of a 99 z28, I know it's ABS, not sure of the channel or whatever. I just know that I have a 2 series rear end. I've found a pretty decent deal on a 10-bolt with 3:42's that I'd like to put in my car. It just doesn't come with the braking system.
Old 04-27-2006, 01:27 AM
Did your car come with traction control? If it did then you have 4/channel abs and bolting up the 3/channel rear you will lose your abs breaking.
No traction control 3/channel abs.
Other than the abs stuff the rears are totally interchangeable.
Old 04-27-2006, 11:27 PM
DFWGrant's Avatar
No. Mine came with a series 2 - no tcs and 2:73's. i'm trying to swap in a series 3 with no tcs & 3:42's in it. Going to use my brakes that originally came on my car.
From what I understand, it should be a pretty straight up swap.
Old 04-28-2006, 04:17 AM
Jon87transam's Avatar
3 channel--abs only. 4 channel--traction control and abs. should be straight bolt up nothing to get in your way except tuning for speedometer, shift points.
