Head Questions.ansa needed ASAP
Old 04-26-2006, 11:51 PM
Cbrakllr's Avatar
Default Head Questions.ansa needed ASAP
My mods are in my sig without the addition of 4.10's or an MS3 or a 400 with a 4000 converter ( all soon to be added) Simply put what are the best heads? I want to run high 10's or low 11's. What heads should I go with? I was looking at the ET 255's or the dart 225's or AFR 225's. Also the Patriot LS6 . What heads will net me the results that I'am looking for?
Old 04-27-2006, 12:02 AM
1slowls1's Avatar
Many heads are good, Just all depends on how much your willing to spend, If you allready have the ms3 I was goin to say just get the head and cam package from tsp. With the 205's, if you go with the 225's theres is alot of milling to be done to get it to the point where it would be good. Other than that ive heard many good things about the PRC LS6 CNC Ported Heads from tsp and for only $999 with comp valve job. Cant go wrong with either the AFR 205's have been proven again and again to produce great flow and power. If i had the money i would def wait for the 205's but there is a nice little wait for them now. Plus if your going to spray they have a nice thick head deck.
Old 04-27-2006, 12:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Moved to internal section.
