Moving Alternator
Old 04-27-2006, 07:27 AM
the_merv's Avatar
Default Moving Alternator
I have no AC in my Car, with the 1LE Pulley bolted in. Is there a Kit that you can bolt the Alternator where the AC Compressor was, or will it directly bolt in.
Old 04-27-2006, 07:56 AM
Somebody09's Avatar
GMRSpeed has an alternator relocation kit for their Twin Turbo setup. Check the forced induction forum. There probably are other kits out there, but I haven't a clue as to who makes them.
Old 04-27-2006, 08:05 AM
the_merv's Avatar
You have a link for it, couldn't find it
Old 04-27-2006, 08:06 AM
LT1BRN's Avatar
check the thread about Engine bays, there alot of ppl who re allocated thier alternators.
Too bad we cant yank the A/C out in this part of the world.
Old 04-27-2006, 08:13 AM
the_merv's Avatar
I saw them, they are all the kits that re-locate to the drivers side. I have no AC Compressor, so I want to use that space for the Alt.
Old 04-27-2006, 08:17 AM
1970judge's Avatar
If im not mistaken i could be though thunder racing has one.
Old 04-27-2006, 08:33 AM
Z284thgen's Avatar
MADMAN should have them in stock i have one on my car no prob with the install
Old 04-27-2006, 08:49 AM
the_merv's Avatar
That looks like it takes the place of the factory Accessory Bracket. No power steering from what I see.
Old 04-27-2006, 09:38 AM
Moderator
BizZzatch350's Avatar
Yep, Mad Mans kit ditches power steering.
Old 04-27-2006, 10:00 AM
the_merv's Avatar
I'll custom make something with the factory Accessory Bracket, then I'll post some pics.
Old 04-27-2006, 02:42 PM
Shon Herron's Avatar
Good luck, hope it looks better than other options, if it does you will have a gold mine.
I think it would be easier to use a SJM kit and then get an LS1 PS pump and mount it on the driver side and run a V-belt off the crank. BUT that is what I would do this summer....
Old 04-27-2006, 02:51 PM
the_merv's Avatar
This is the thing, does the LS1 pump pulley spin against the inside or the outside of the Serpentine belt. That is the current thing i am running into with the LT1 Power Steering pump.
