ls6 heads
Old 04-27-2006, 11:01 AM
kingb's Avatar
Default ls6 heads
i came across a set of ls6 heads 650 for the pair. are they worth the trouble. i have a 98 ss thats basically stock and i want to either build an ls1 or a 6.0 for the car. any advice
Old 04-27-2006, 03:56 PM
Gunnar@Patriot's Avatar
The LS6 heads will show definte improvements over your stock LS1 heads. Not only will the flow improve, you will also up your compression to 10.5-1. If you are looking at doing the swap, we can do you a set of brand new 243 castings assembled with oem 2.00"/1.55" (non-sodium) valves and LS6 springs for $675.00 shipped anywhere in the US. We can do these same heads in a CNC ported version that will flow 300+ @ .600" for only $875.00 shipped.
