valve springs how long will they lat?
Old 04-27-2006, 12:09 PM
dhpewterz's Avatar
Default valve springs how long will they last?
Ive got a set of patriot duals that are starting to make a little more noise than when i installed them ive got about 20k miles on them now someone told me about every 20 they needed to be changed is this true?
Old 04-27-2006, 12:16 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Depends on how hard they were ran...but yeah definitely check them out. It may be time to swap them.
Old 04-27-2006, 12:42 PM
dhpewterz's Avatar
They have been run pretty hard so do most people change that quick?
Old 04-27-2006, 12:43 PM
Steel Chicken's Avatar
depends on how aggresive the lobes on the cam are. XE-R or LSK lobes will wear out even heavy duty springs in 20K miles
Old 04-27-2006, 01:25 PM
GuitsBoy's Avatar
Yes, Please let us know what kind of cam. 20K miles worth of hard driving is going to take its toll on a spring even on a small cam. Contact gunnar@patriot and he'll ship you out a set of replacement coils so you dont have to buy a whole new kit. I just got mine a couple months ago from gunnar and youll be pleasantly surprised how little he wants for them. Once you get them, pop out the cylinder 1 plug (or all of them) and find TDC. Then use the TDC method from the ls1howto cam swap article. Put a dot of whiteout on the crank pulley so you can use that as a reference for every 90* turn. Shouldnt take more than a couple hours to swap the valvesprings.
Old 04-27-2006, 03:00 PM
AdamSS's Avatar
3000 miles on my Patriot Duals with F10 cam (228/228 0.577 lift) So far so good, but I plan on changing the springs at 20,000 miles or so...
Old 04-28-2006, 03:14 AM
dhpewterz's Avatar
ive got the g5x2. so guess its time too change. damit i hate doing springs!!! thanks for all the info.
Darren
Old 04-28-2006, 02:05 PM
eamador11's Avatar
Mine are noisy too. have about 16k im going with comp 921s next time.
Old 04-28-2006, 03:40 PM
GuitsBoy's Avatar
Ive noticed my springs quieting down after the first couple thousand miles...
