How are dynotech driveshafts?
I was told that these are very nice...and on par with a Denny's driveshaft. Does anyone have any experience with them.
What other driveshafts do you recommend for 450-700rwhp?
I have been using a MMC one for about three years now with no problems at all. I did explode the posi in a Moser 12 bolt 2 weeks after I got the Drive shaft. I now run a Moser 9 inch and leave at 5500 rpm or higher with no problems. I make a touch over 500 at the tire.
Metal Matrix Composite Aluminum
● Application: High Performance Street and Racing
● Higher torque & Rpm Rating than 6061-T6
● Tube Size: 3.5" X .115" Wall
● Weld yokes: 1330, & 1350
[QUOTE=LT99LS1]I have been using a MMC one for about three years now with no problems at all. I did explode the posi in a Moser 12 bolt 2 weeks after I got the Drive shaft. I now run a Moser 9 inch and leave at 5500 rpm or higher with no problems. I make a touch over 500 at the tire.
[center]Metal Matrix Composite Aluminum
The Moster 12 bolt issue really had nothing to do with the driveshaft though....right??
