Halo Install Question . . .
1 Post
I just purchased a used set of Halo's (thanks Lithium!) so i dont have the instructions
What do i hook the two little halo light wires up to? im not supposed to run a seperate circuit am I? Im assuming i splice them into one of the headlight wires.
-paul
-paul
-paul
-paul
I assume you ground one wire and send the other to a switched power source...
I bought a set from quiet_storm98 and plan on hooking them up to the factory foglights.
I am also going to make it so that my factory foglights can be turned on independently of the headlights coming on. This way if I want them on during the day the will be but if not they won't (I still have my DRL's so if I hooked them up to the turn signals they'd be on all the time)...
Mine are spliced to the fogs.
Then I killed the auto headlights in the Camaro
Now the Halos are on a switch! (fog switch now turns the fogs and halos on) so in the evening I can drive with headlights and halos or just the ring.
