Impala head gasket #?
Originally Posted by 95wht6spd
Thanks! I tried Googling, but couldn't find the #.
Know of an inexpensive place to get one?
Google...
GMPartsdirect.com works just fine, then you call up your favorite parts guy such as DAl, and Boom parts
GM PART # 12553160
CATEGORY: Engine Cylinder Head Gasket
PACK QTY: 1 CORE CHARGE: $0.00
GM LIST: $37.85
OUR PRICE: $22.44
DESCRIPTION: HEAD GASKET (LT1 IRON HEAD)
Composition gasket for 1994-2001 iron head LT1 engines.
Originally Posted by the_merv
FELPRO # 1074 is a good one, it is .039"
The ONLY way I would recommend that gasket is if the block were zero decked.
Word is the Victor Rienz from NAPA for the b-body is .026 as well.
Stock deck height is .020-.025 ideal quench for most of us is a bit under .040, you do the math, even with the .026 gaskets quench is likely to be right around .050. Not to mention the extra compression helps drivability with bigger cams. I recently took a nearly 20 degree jump in intake duration along with a over 1 point compression increase and drivability has stayed nearly the same. Slightly rough at low rpm TC lockup but more tuning will resolve that.
Yes Felpro specs the .039 for the f-body but that doesn't mean it is best for a modded car, it is better than the stock .049 though.
