Best way to flush clutch fluid....??
I use a turkey baster and suck out as much fluid as I can, then drive it and repeat it a few times. I know it's not perfect, but it sure is easy and it helped solve my engagement problem on high RPM shifts.
Ditto. Exactly what I do.
If you have to do a complete flush as in changing the type of fluid you are using, that's a different story. I'd start with the above, put a tube on the end running to a jar of fluid, then open the valve in the slave and have someone add fluid as you slowly pump the pedal. There are other ways too.
Kleeborp the Moderator™
Same question here:
https://ls1tech.com/forums/manual-transmission/499362-just-sent-my-t-56-t56-rebuilds-now-i-have-master-slave-question.html
...and I'd like to know the answer too.
