Help me....
Help me....
Okay yestI hooked up a Dry zex kit in my z28. And we got it all done and everything, then when i started the car the e-brake light was on and so was the ABS light and the lieft side blinker ligght . Also the wipers wont work and when I turn them on it makes my headlight brighter and dimmer with the turn of the wipers. My drivers side bright lights wont work either......WHAT THE HECK HAPPENED???
I assume "we" know everything we did during the install ?
It's either going to be where you took the power from for your system, or where you chose to ground your system that is causing the problem... well assuming you didn't break something else during the install.
Restricted User
Did you mess with the small ground wire right up on the radiator support? If not tightened all the way down, I believe that is the same one that gave me those symptoms when I swapped engines. Its either that one or the one directly below the fuse box on the drivers inner fender, but IIRC it should be the one on the rad. supp. Let us know.
Charlie
Charlie
Was the ground on the radiator support everything works now. Only problem is the abs light is still on hmm not sure bout that one. But ill figure it out its all working now that was my major concern. thanks guys you saved me many hours of hunt and find. Gotta love this board.
