Good machine shop?
Good machine shop?
im looking for a good machine shop to get my ls motor heads and cams from in the DFW area. City motor is what my friend has used in the past but i cant find their website.
What are some good shops around ?
Originally Posted by AgFormula02
Why are you looking for a machine shop to buy heads and a cam from? Plenty fo sponsors to do that from. Usually use a machine shop to build motors and do, well, machine work.?
What sponsors would you recomend? ill just find the place i was looking for if nothing else comes up.
I had my shortblock built by Wyane calvert in denton. But as said before, if you're buying a heads and cam combo, you should definetly check out a sponsor. Id say TSP, Patriot, AFR, comp cams, and there are a bunch of others that I cant think of at the moment for some reason.
