Pump on back of LS6?!?!?!?
Old 04-28-2006, 07:45 PM
Robinator's Avatar
Default Pump on back of LS6?!?!?!?
what is the pump on the back of the LS6 manifold? The AIR tubes attach to it and then 2 very small thin lines go to the back of the intake manifold. If I delete the AIR system, can I remove this as well or is it for something else? Car is a 01 Z28
Thanks
Old 04-28-2006, 08:28 PM
bastien's Avatar
I don't think you can remove it, so just plug it with a screw.
Old 04-28-2006, 09:06 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Yeah thread a screw into it...should be fine.
Old 04-28-2006, 09:20 PM
Robinator's Avatar
are you talking about plugging the intake with a screw?
Old 04-28-2006, 10:28 PM
SUX2BU's Avatar
take it all off. there is a ruber TEE pluged on the back of the intake. the part that goes to the passenger side in for your a/c controls. the part that goes to the driver side is for that AIR solenoid thingy.
take it all off and just plug the A/C control line to the back of the intake.
Old 05-01-2006, 01:28 AM
Robinator's Avatar
I removed it and it is SO much better looking in that engine compartment now.
Old 05-01-2006, 03:12 AM
That's what she said...
TheBlurLS1's Avatar
It clips into a slot on the intake manifold. You push the clip down with a screwdriver to get it to slide out of the slot, or you will break the plastic.
Old 05-01-2006, 03:21 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Glad to hear that you didnt have to screw anything.
